5th gear grinde.....HELP!
Well, when I shift into 5th every once in a while(1 out of 7-10 times going into 5th or so) it will grinde when i try to push it into gear, I have the t-45 tranny, is this a sign of my transmission starting to break down? And sometimes it is hard to get into 1st and 2nd at times.....Please help, i don't want my transmission to go on me, if there is a way to help stop this please let me know as well.
Thanks!
Thanks!
RE: 5th gear grinde.....HELP!
if 5th is grinding and 1st and second are being hard to go into.
try adjusting the clutch. some of the stock ones you can lift up on the clutch pedal and then push it to the floor.
normally with grinding it will be the synchro's but think this is more clutch adjustment I believe
Okay good, is adjusting the clutch something i can do? (i'm not very mechanically inclined, but i have family that knows about this stuff probably) but how do you adjust it? if it's not to much to explain....
ORIGINAL: 01yellowgt
Synchros. I have an 00 V6 same problem.
You can call the dealership to see if they have suggestions though...
