oil change ?
oil change ?
what size oil filter wrench do i need for the oil filter ? and whats the best way to drain every bit of oil out? ramps ? jack up the side to get under it to pull the plug and then lower it to drain? wich way should i go about getting it all out? and when filling with oil does the car take exactly 6.0 quarts? thanx
RE: oil change ?
I don't know what size wrench for the filter. I use K-N oil filters and they have a 1 inch nut on the back.
I usually get the car started draining then jack up the pass side a little and let it sit for 6 or 7 mins. Drop her, plug her, and give her 6 nice shots of Royal purple.
I have put in 6 quarts everytime and it falls right where it should, about 3/4 of the way up the hatched marks on the stick.
That reminds me, I need to order some oil!
RE: oil change ?
The best way to remove the oil filter with out getting a Drop of oil anywheres is.
Get a 1 Gallon Plastic Ziplock Bag. And place it totaly around the filter when removing it then everybit of oil will stay in the bag then Ziplock it closed. Presto all done and No mess.. If you Value your Car always change your Own OIL...
Here's my toys
[IMG]local://upfiles/6214/Db856385786.jpg[/IMG]
[IMG]local://upfiles/6214/Je997395790.jpg[/IMG]
[IMG]local://upfiles/6214/Xc782215518.jpg[/IMG]
[IMG]local://upfiles/6214/Rl262364840.jpg[/IMG]
Here's my toys
RE: oil change ?
ive seen that on mustang world that you need to jack up the passanger side cause the oil sits in the corner of the pan. cool thanx didnt know if that was needed but ill do it that way. if anyone knows the measurements for the oil filter wrench it would be a big help. im using amsoil and amsoil filter but i still have to take off the motorcraft filter.
TfcCDR
09-14-2015 12:08 PM
