Some help
Old 06-28-2004, 01:10 PM
Moosetang
Moosetang's Avatar
Default Some help
Ok guys, I know this is way off 4.6 subject but it seems more of you guys have aftermarket wheels and tires. I just bought 2 18x9 Saleen's and 2 18x10 Saleens. My question is to stay with 4 Kumho tire's I have to go 255-35-18 up front and 295-35-18 in the back. But will the 255's rub in the front? I have 235-55-17's up there now with my old Cobra's and they rub when I hit a bump. But it might be because of the huge sidewall. Anyways give me some opinions.
Thanks
Moosetang is offline
Old 06-30-2004, 06:20 PM
Moosetang
Moosetang's Avatar
Default RE: Some help
bump
also, the car's lowered 2 inches
Old 06-30-2004, 07:34 PM
USAMuscle
USAMuscle's Avatar
I have 235/45/17 tires on my car all around and they never rub. Maybe try a smaller sidewall.
USAMuscle is offline
Old 07-01-2004, 01:33 AM
Moosetang
Moosetang's Avatar
I'm not putting tire's back on the Cobra's. I'm just trying to figure out what size to put up front with the new Saleen's. Thanks anyways though.
Old 07-01-2004, 01:13 PM
Monty
Monty's Avatar
Im running 255 45 17
(if that helps????)
Monty is offline
Old 07-01-2004, 08:12 PM
Moosetang
Moosetang's Avatar
Your car dropped? I'm thinking I should be able too.
Old 07-01-2004, 08:44 PM
03Muskrat
03Muskrat's Avatar
a 255/35/18 should be fine
the stock cobras have 275/40's on them, and they dont rub, and those tires are a bit wider then the ones mentioned above, by 4/10 of an inch, how far is your car dropped?
03Muskrat is offline
Old 07-01-2004, 09:06 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
My ride is dropped 1.6 in the front and 1.5 in the rear... will 275 40 DR 17's work oin mine??? Thats what im going for the next time I go shopping for tires.
jdaniel is offline
Old 07-05-2004, 03:22 AM
Moosetang
Moosetang's Avatar
Alright cool i should be good then.
Old 07-06-2004, 02:46 AM
neogenic83
neogenic83's Avatar
i have 275's and have had zero clearence problems and my car is lowered 1.5 not a big diffrence but none the less the only problem i have had is since they are wider they like to spray up the side sometimes
neogenic83 is offline
