crackling at high RPM
Old 09-01-2006, 02:29 AM
bryanec
bryanec's Avatar
Default RE: crackling at high RPM
Cracking and popping at WOT usually means very lean condition. Check all the connections on your intake and vacuum lines (as frostbite said). Clean your mass air. Then richen the mix with your tuner. If it sounds like a hammer hitting steel then it is detonating. Back off your timing and clean the cylinders with seafoam before your next oil change. Hope this cures it.
bryanec is offline
Old 09-01-2006, 05:06 AM
wildazme
wildazme's Avatar
im having the same problem as you and ive had the problem under wot with the stock tune, a superchips 89 tune and the 93 tune. I always use 93 octane in my car even on the stock tune and still get this sound. I have used seafoam in the engine and i have also changed my plugs and wires to no avail. i cleaned my maf sensor with throttle body cleaner and the problem doesnt go away. i have no vacume leaks at all either. I have no idea what this problem could be.
wildazme is offline
CS2007
06-25-2019 09:45 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Sixer4Life
10-12-2015 04:26 AM
Drastang
09-30-2015 03:48 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: crackling at high RPM
