tensioner pulley
tensioner pulley
if i push on the belt on the right side of the alternator, i can push it down to the water pump, and the tensioner gives a little. is that normal? i figured there should be a lot more tension than to be able to push the belt down that far. anyhoot, just thought i'd ask you lovely ppl
RE: tensioner pulley
yeah do you hear anything while driving? May be a startup squeal, faint squeak when you let off the gas and/or shift gears...
i'd say get an OEM motorcraft tensioner and a gatorback 'goodyear' belt... those are the shyt
