A good deal on a vortech?????
Old 09-12-2006, 11:03 PM
red99droptop
red99droptop's Avatar
Default A good deal on a vortech?????
I have come across someone selling a vortech supercharger kit brand new here is the parts list. He is asking $1400.00. Should I jump all over this deal it is brand new still in box also.
Part No. 4FL218-130SQ/138SQ
PARTS LIST
Part Number Description Quantity
4FH130-026 OIL FEED ASSEMBLY 1
7U030-026 1/4" x 26" Oil Feed Hose 1
7P525-067 .525 Crimp Ferrules 2
7P250-066 #4 Swivel x 1/4" Hose Barb Fitting 2
7P125-103 1/8" NPT -4 x 45° Male Elbow 1
7P250-082 1/4" NPT x -4 90° Fitting 1
7P250-034 1/4 NPT Street TEE 1
7P250-036 -4 Flare to 1/4 NPT 1
4FH130-036 OIL DRAIN ASSEMBLY 1
7U030-036 1/2" x 14" Oil Drain Hose 1
7R001-008 #8 Stainless Hose Clamps 2
7P500-003 90° 1/2" Alum. Tube 1
7P500-020 Tube Nut 1
7P375-042 Male Connector 1
4FH112-020 DISCHARGE ASSEMBLY 1
4FH012-020 Discharge Tube 1
7S300-200 3" x 2" Sleeve 1
7S275-200 2-3/4" x 2" Sleeve 1
7R002-044 #44 Hose Clamps 2
7R002-048 #48 Hose Clamps 2
7R002-016 #16 Hose Clamps 6
8D001-001 Bypass Valve 1
7U034-016 1" x 3.5" Heater Hose 1
7U034-016 1" x 13.5" Heater Hose 1
7U030-046 5/32" x 52" Vacuum Line 1
7P156-082 5/32" TEE 1
7P100-010 1" Hose Union 1
7U133-090 1" x 90° Rubber Elbow 1
4FL120-020 ECM CHIP PACKAGE 1
4F060-038 38lb. INJECTORS 8
8F001-265 Fuel Pump 1
4FL139-096 PCV ASSEMBLY, 2004 Mustang GT 1
4P375-106 PCV Valve 1
7P625-375 5/8" to 3/8" Reducer Barb 1
7U032-016 3/8" Hose (6") 1
7U033-000 5/8" Hose (6") 1
7R001-006 #6 Hose Clamp 4
2E229-130 SUPERCHARGER ASSEMBLY 1
2E128-030 V-2 SQ Supercharger 1
2A036-360 3.60" Supercharger Pulley 1
8R101-001 6 Rib Pulley Retainer Assembly 1
4FL111-031 MTNG BRKT ASSY, '00-'03 2V GT 1
7A375-178 3/8-16 x 1-3/4" HXHD G8 5
7K375-040 3/8" AN960 Flat Washers 5
2A046-080 Belt, K061080-Gates Saleen 1
4fl011-031 Mach, 2000 GT Mtg Brkt 1
7C080-065 8mm X 1.25 X 65 Soc 1
7C080-140 8mm X 1.25 X 140 HXH 1
7K312-001 5/16 AN-Washer 4
7C060-050 6mm X 1.0 X 50mm HXHD Zinc 1
7C080-025 8mm X 1.25 X 25 HXHD 1
4FE014-010 Radiator Pipe-Stnlss 1
7R002-024 #24 Gold Seal Hose C 2
7R003-013 Adel Clamp, 3/4" ID 1
7C010-050 10-24 X 1/2 Soc HD Cap, Zinc Plt 1
7J010-001 #10 Flat Washer 1
7C010-140 10mm X 1.50 X 140 Hex Head 2
7J010-002 10mm Washer, Zinc Plated 4
7C010-066 10mm X 1.5 X 65 Bolt, SHCS 1
7E010-046 #8 X 3/4 Sheet Metal 1
4FL116-150 2000 2V Idler Ply Assy. 1
4FH111-032 Idler Plt Assy, 2V GEN3 1
4FH016-150 Idler Pulley, 6Rib 3" Flangd 1
4FA016-171 Dust Cover (Idler Pulley) 1
7C012-020 12mm X 1.75 X 20mm Pld 1
2A017-045 Spacer, Idler Plate 2V G3 1
7A375-208 3/8-16 X G8 HXHD 1
7J250-001 1/4 SAE Washer, Pltd 1
7C080-140 M8 x 1.25 x 140 Bolt 2
4FH112-010 AIR INTAKE ASSEMBLY 1
4FA012-012 90° Intake Elbow 1
4FH110-050 MAF Meter Bracket Assembly 1
7R002-056 #56 Hose Clamps 6
7S350-200 3-1/2" x 2" Sleeve 2
7U035-000 3-1/2" x 9" Flex Hose 1
7R002-052 #52 Hose Clamps 2
8H040-090 Air Filter 1
7A250-075 1/4-20 x 3/4" SHCS 4
7F250-021 1/4-20 Nylock Nuts 4
7J250-001 1/4" SAE Washers 4
4FK012-040 Inlet Elbow 1
7P750-100 3/4" NPT x 1" Hose Fitting 1
7U033-000 5/8" x 48" Hose 1
7U038-000 3/4" x 27" Hose 1
7U100-052 7/16" Rubber Grommet 1
7P625-002 5/8" Barb 1
4FH012-012 90° Inlet Elbow w/Hole 1
red99droptop is offline
Old 09-12-2006, 11:08 PM
2000GT4.6
2000GT4.6's Avatar
Default RE: A good deal on a vortech?????
if everything is there like it says, and the blower isn't wrecked, for 1400 bucks you cannot go wrong.
2000GT4.6 is offline
Old 09-12-2006, 11:15 PM
red99droptop
2000GT4.6 Date 9/12/2006 9:08:30 PM
He says it is brand new in box.
Old 09-12-2006, 11:46 PM
mikev08826
I ♥ Acer
mikev08826's Avatar
Yes, buy it.
mikev08826 is offline
Old 09-12-2006, 11:50 PM
red99droptop
Is there anything else I would need to get up and running safe. I will get it tuned by this shop I have my work done at. Also about how many hp to the rear wheels can I get from this set up.....any estimates
Old 09-13-2006, 12:02 AM
Hulk99
Hulk99's Avatar
I would definately check it out in person and if its legit let me know so I can buy it! Awesome deal if everything is working.
Hulk99 is offline
2000GT4.6
2000GT4.6's Avatar
assuming you have a good tune and basically a othewise stock car 360~ to the tire, depending on boost level.
Old 09-13-2006, 12:04 AM
Hulk99
Hulk99's Avatar
ORIGINAL: red99droptop
Depends on your other mods such as exhaust, etc. I would say just the kit would put you around 350 to the wheels. With full boltons and cams you could be into the 400s.
Hulk99 is offline
red99droptop
Can not check it out in person, its not in my state, I am a little nervous about it kinda a big purchase for me. I was saving for the mongoose kit from mph but this is a ton cheaper. almost by half. Not the same kit but pretty close.
As for mods I just have bbk x pipe and flows and some suspension work for now.
Old 09-13-2006, 12:06 AM
Hulk99
Hulk99's Avatar
The price kinda scares me, why are they giving it away? A new kit like that could easily pull 2k from a buyer.
Hulk99 is offline
Quick Reply: A good deal on a vortech?????
