Throttle Body ?
RE: Throttle Body ?
Don't forget that only 5mm difference in diameter makes a big difference in surface area. a 70mm throtle body yields 3846mm in surface area while a 75mm throttle body is 4415mm of surface. That's a pretty big difference. Not sure which is better for your current mods though.
RE: Throttle Body ?
you are going to be disapointed with the C&L plenum.... you will gain some, but not what you would with the accufab. hopefully i can sell my pos c&l and get the accufab... accufab... accufab... accufab....
if you are N/A, stick with the 70mm and get the accufab plenum.. i guarentee you won't be dissapointed.
RE: Throttle Body ?
70 mm throttle body - your doin it right as well - a throttle body and plenum change isn't worth the money unless you invest in something like a densecharger and an aftermarket mass air meter. You'll be happy with the SOTP difference. Oh and WHT is right on with the accufab comment - they are the best there is out right now - It will outperform C&L by a good 30% more hp - only thing is that 30% is only = to about 2.5 hp hehe.
