rattleing?
Old 07-19-2004, 08:30 PM
GIGM08GT
GIGM08GT's Avatar
Default rattleing?
I have a 99 Gt and I have this problem with a 'rattlling can' sound that happens when I put just a little extra pressure on the gas in first second and sometimes third(if I push it). Can;t figure out what it is. Sounds like its comming from the middle of the car. Can anyone help me out? Is this supposed to me normal?just got it back on the road after sitting a month.(stupid DMV) Thanks
GIGM08GT is offline
Old 07-19-2004, 08:31 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: rattleing?
Get the car up in the air and start banging around and try to duplicate it. Sounds like a heat shield.
I'll let everyone else chime in with the real bad news if that isn't the problem..
Dan04COBRA is offline
Old 07-19-2004, 08:39 PM
GIGM08GT
GIGM08GT's Avatar
what could this real bad news be? now you got me scared
GIGM08GT is offline
Old 07-19-2004, 09:30 PM
GIGM08GT
GIGM08GT's Avatar
If you think its one of the cats, that won;t be a prob on Thursday Finnaly gettin my H-pipe put on cause I don't have easy access to a lift.
GIGM08GT is offline
Old 07-19-2004, 10:07 PM
01GTvertible
01GTvertible's Avatar
could be bad gas, or cheap gas. my 01 gt's valves make kind of a rattling sound when i get cheap and put low grade gas in it. sense your stang sat for a while, this could be the problem. id put fuel treatment in it, and run the tank down and fill er up with high octane gas.
01GTvertible is offline
Old 07-19-2004, 10:21 PM
Acer2428
Site Mod
Acer2428's Avatar
SAME THING HERE!!!!!!!!!!!!!!!!!!
I finally said F it and brought it into the dealership...They thought it might either be:
A) Bad Cat (If it is, Magnaflow employees should sleep w/ one eye open)
B)Broken/chipped flex plate
Is your car an auto? I thought maybe mine was bad gas, but 1/4 tanks of 94 octane didn't help.
Acer2428 is offline
Old 07-20-2004, 01:48 AM
98cobrasvt
98cobrasvt's Avatar
Fuel injector cleaner or it may be the a/c vents rattling like mine...
98cobrasvt is offline
Old 07-20-2004, 01:53 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
I didnt have that problem till I got the X pipe and I assumed it came with the pipe. Its really mild and its only there when im on it really hard. Other than that it has the deep tone of magnaflows.
jdaniel is offline
Old 07-20-2004, 11:19 AM
pichinco
pichinco's Avatar
If it's really coming from the middle of the car, versus the engine, there isn't a whole lot to worry about. It's something loose. Heat sheild, exhaust, etc. If your having exhaust work done, have the guy look around while he's under there and look for something obvious. If you still have the same thing after Thursday...make SURE it's not the engine.
Pre-ignition knock is caused (as others have said) by cheap gas, too low octane, dirty injectors, dirty fuel filter, or dirty fuel system in general, contaminated MAF, mis-gapped plugs, etc. Beyond that you gotta dig pretty deep.
pichinco is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
UrS4
09-30-2015 10:13 AM
2015Ecoboost
09-17-2015 01:48 PM
movielover40
09-15-2015 10:37 AM
tmdm
09-04-2015 06:45 PM
Quick Reply: rattleing?
