15x10 inch rims
RE: 15x10 inch rims
They will fit with no rubbage when I launch? I am buying the crager street star 15x10. What size drag radials should I put on? I sold my weld drag lites for $300 and I got these both for $100. Do you think the weight is about the same?
RE: 15x10 inch rims
I think the tire size will be more important than the rim size, you may need to remove your quad shocks either way though. Im not real sure though I should even be posting in this thread.
RE: 15x10 inch rims
Hey nomo what do you think about these rims. They are located @ www.summitracing.com They are the crager street star. Thanks
RE: 15x10 inch rims
not sure how much they weigh man, but back when i had the cobra, i was going to get 18X11 ccw's with 315/35 tires. i called them up to verify it would work, and they said you could use up to an 11" wide tire with no body modification. but like md said, the tire width is what is going to matter.
RE: 15x10 inch rims
I know, I know, That company doesn't make those in 15x8. Only 15x10's and so on. I have to hurry because I am going to the track on August 6th. I would rather ask you fellas, because summit doesn't like fords, plus you guys can post more for "moderator" status.
