This is what a ported 70mm FRPP throttle body + plenum looks like
All for the mere cost of $115.00 shipped (bought the tb used from a member here - can't remember his screen name to give him credit though)
The portwork only cost time.
ACCUFAB WHO?
RE: This is what a ported 70mm FRPP throttle body + plenum looks like
ORIGINAL: Sn98Gt
The accufab still outperforms a fully ported stock plenum. allghough not enough to justify spending 400 some odd bucks for the accufab plenum/tb setup.
They both are, they are port matched as well - although you see what appears to be a ridge there between the two thats some kind of light flash or something because they are flush. The throttle body was only slightly ported so that it would not be larger than the plenum, basically the casting ridge in the FRPP throttle body was smoothed and the throttle body was only opened about 1 mm larger. The plenum was fully ported to get the most flow, but is still thick enough to not worry about cracking.
depends on if you want the outside polished as well. I'd do the inside alone for $35 and polish the outside if you want for an additional $35. I do heads too but thats a lil more. I can have a set of worked heads cleaned, decked, and with a valve job shipped to your door (with a core charge). PM me if interested. I can show some of my work before hand if necessary, and I can get flow #'s as well if you want.
Md, you are the shiznit! When you mean polished on the outside, do you mean chrome the outside? Sorry I know damn noobs. Still a little hung over over here. Send me an email (if you can) with your info. jon.straszewski@bankcardusa.com I know, I know, my last name is f'd up. I didn't learn how to spell it till I was like 18. LoL Thanks alot Can you give me details on the heads? not alot
