Is this common?
Old 07-23-2004, 07:38 PM
Jeffs_GTstang
Jeffs_GTstang's Avatar
Default Is this common?
I just got my 96' GT. The 5 spd. manual tranny works very well, and the clutch is extremely tight. Only think I noticed is that when I go to put it into reverse, it'll grind, despite the fact that the clutch is fully depressed, and the car is not moving. Sometimes if I push the shifter far to the right, it'll go in a little bit easier. Getting into any other gear is just fine, its just the reverse. Is this common on my Mustang. Perhaps I just need to get used to this tranny? Thanks...
Jeffs_GTstang is offline
Old 07-23-2004, 07:48 PM
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
Default RE: Is this common?
Common on almost all stick shift cars. Try putting it into first, let the clutch out just a hair so it rolls forward about an inch, then go to reverse. That should stop the grind. I'm not positive on this one, but I don't think there are syncros in reverse.
Sidewayz6.0 is offline
Old 07-23-2004, 07:49 PM
RJM02GTDrag
RJM02GTDrag's Avatar
They all do that! I just go up into 5th and back down and it goes in.
RJM02GTDrag is offline
Old 07-23-2004, 08:06 PM
Js281GT
Js281GT's Avatar
Yup my car does it too. I just go into 4th then double clutch into reverse. Once you get an aftermarket shifter I don't think it will happen anymore.
Js281GT is offline
Old 07-23-2004, 08:15 PM
Obsol3te
Obsol3te's Avatar
<---has an aftermarket shifter
And it still does it.
Didn't know all stangs did it
Now i feel better.
Obsol3te is offline
Old 07-23-2004, 09:05 PM
dwhite645
dwhite645's Avatar
it happens because the reverse gear is still spinning. Mine will spin for about 5 seconds immediately after pressing in the clutch and will occasionally get a little grind. As others said you can go into another gear first and then wait a few secs and it'll align itself and go in without any grind.
dwhite645 is offline
Old 07-23-2004, 09:34 PM
Mach1
Mach1's Avatar
When i had my sho it would always grind into reverse, so b4 i went into reverse i put the clutch in and go into 1st, 2nd, 1st, 2nd and then reverse and it wouldnt grind. My mach1 doesnt grind at all.
Mach1 is offline
Old 07-24-2004, 07:00 AM
MineralGreyGT02
MineralGreyGT02's Avatar
I just push the clutch in and, as the tranny gears spin slows down almost to a stop, shift into reverse. If it doesn't slip in I leave it in neutral, let out the clutch so the gears spin back up, press the clutch in and as they slow down try again. I normally get it on the first try. Almost always on the second. Just my way of doing it... Come to think of it, mine doesn't "grind" going in reverse. It's just a biatch to get it to engage.
Also, reverse does have a synchronizer...
MineralGreyGT02 is offline
Old 07-24-2004, 02:03 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
I have never had this problem before. It goes into every gear just right for me.
jdaniel is offline
Old 07-24-2004, 05:08 PM
01GTvertible
01GTvertible's Avatar
or you could be a sissy like me and get a dogomatic , but to my defense, the car was originally intended to be the wifey's everyday driver.
01GTvertible is offline
CS2007
06-25-2019 09:45 PM
drfister
05-03-2018 10:38 PM
9550
10-26-2015 05:01 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Is this common?
