stock MAF - whats with the screen?
Old 07-29-2004, 05:34 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: stock MAF - whats with the screen?
As a matter of fact, aftermarket meters are just stock mass air meters in a bigger tube with no screen - but their calibrated to work without the screen.
You must not be running a C&L setup . Not to argue, but not only are most aftermarket meters smoother and better flowing (in addition to being bigger), but they don't have a rather large plastic peice running vertically thru the airstream (holding the sensor) as does the stock plastic unit. Crap like the stock A/F meter is why the 4.6 benifits so much from aftermarket boltons.
2000GT4.6 is offline
Old 07-29-2004, 11:51 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
OK so to be more specific aftermarket meters are just stock mass air meters in a bigger tube with no screen and have the post removed.
To my knowledge all of the aftermarket manufacurers of mass air meters use the factory stock electronics which are recalibrated. The screen is the biggest restriction of the entire intake tract.
mdvaldosta is offline
Old 07-29-2004, 12:56 PM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
you know that if the car is running and you put your finger in front of the screen, it fvcks the idle all up until you take your finger away. Obviously because it changes the flow of the air but interesting, still.
MikeHawke is offline
Old 07-29-2004, 01:10 PM
pichinco
pichinco's Avatar
29!! Good grief!! The best I've gotten on a road trip, no A/C was ~23 mpg. That's insane out of a V8. Normally I run 21-22 unless I've got my foot in it a lot. Course a lot of my driving is highway.
pichinco is offline
Old 07-29-2004, 01:18 PM
Monch
Monch's Avatar
I think i'll play it safe and just buy an aftermarket one. Thanks for the help everyone.
Monch is offline
Old 07-29-2004, 01:56 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: pichinco
no doubt. I cannot see how a 99+ 4.6L is capable of 29 MPG. Before any modifications were done to my car, other than a K&N and flowmasters, I was averageing 20 MPG, with a all time best of about 23-24MPG.
Old 07-29-2004, 02:08 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
I think I only get about 15 mpg now, maybe less the way I drive
Old 07-30-2004, 02:17 AM
AirForce2004
AirForce2004's Avatar
I think me driving at 4000 rpm is effecting my milage... just a bit.
I read in fast ford mag that the screen is absoultely useless and wont effect anything if gone... on the negative side.
They said youll get more airflow at higher rpms with it gone.
AirForce2004 is offline
Old 07-30-2004, 01:51 PM
Race1Mopar
Race1Mopar's Avatar
ORIGINAL: 2000GT4.6
ORIGINAL: pichinco
I'll come to his defense. I average 19 or 20 in daily driving because my foots always in it. When I go out of town, depending on the day (light traffic=faster) I do ~75-85mph for ~130 miles and 85-95 for ~130 miles and average 21-24mpg. I had to go to Dallas once and the traffic was so heavy I HAD to do 65mph the whole way.
I was so shocked... tap tap tap on the gas guage... pulled over to put gas in it at ~150 miles and 3/4 tank of gas cause something has to be wrong with my guage. I only had to put in just over 5 gallons of gas which when I calculated was 28.4mpg!!! OMG I was flored Too bad my foot hasn't had the opportunity to do 65 for a long period of time since so now I still average my 23 or 24mpg on long trips. dang right foot [:@] hahahaha
Race1Mopar is offline
Old 08-01-2004, 12:31 PM
Monch
Monch's Avatar
well out of boredom yesterday i pulled the screen out.
i left the battery unplugged for about half an hour, ensuring that the computer would do a reset. don't know anything about this, someone suggested it above and it sounded like a reasonable thing to do. i also put the rubber "gasket" that held the screen back in, so there wouldn't be any leaks.
initially the car had a somewhat rough start, and idled roughly for the first 10 seconds, after than everything was back to normal. took it out for a spin and noticed an improvement in throttle response. it just seemed more eager to get to and live at 3000+ rpms. I noticed a small improvement in power, more pep is all, nothing major.
i didn't get past 4500 rpm, i want to believe that everything is fine before i tax it. i've since started it/drove it twice more and there appears to be no problems yet.
Monch is offline
Quick Reply: stock MAF - whats with the screen?
