Is reving your engine hard on it ?
Old 07-31-2004, 10:57 AM
GrayGhost01GT
GrayGhost01GT's Avatar
Default RE: Is reving your engine hard on it ?
Yo thanks everyone for your input alot of you made me feel better now I know to take it a little bit easier on my baby thanks guys !!!!!
Phil
GrayGhost01GT is offline
Old 07-31-2004, 09:48 PM
01GTvertible
01GTvertible's Avatar
ORIGINAL: Mach1
I thought the automatic stangs had like a 4k rpm rev limiter when its in park/neutral.
naw, i rev mine to like 5500, but not all the time, only when i am going under a bridge, to hear that ROAR. but when in park/neutral, i can rev the heck out of it if i wanted to.
01GTvertible is offline
Old 07-31-2004, 11:25 PM
vfast
I ♥ Acer
vfast's Avatar
it is hard on an engine freewheeling the engine as we called it..this is when valve floats and rods go....as there is no load ...I'm sure the trans didn't like it....I had gone 70mph in an old gto and drunkingly put in first as the rear locks up for a sec or 2 and about a 50 foot patch of rubber is laid down and a nice flat spot on the tires
vfast is offline
Old 07-31-2004, 11:35 PM
04ShakinSteed
I ♥ Acer
04ShakinSteed's Avatar
ORIGINAL: Dan02GT
It won't hurt nothing by revving it in neutral man.
I don't know why anyone is making a big deal about it here. The motor is spinning freely, no load is on the engine. You could rev it night and day and it will last just as long as a never revved engine.
The reason they are making a big deal is the kid is revving it up high and dropping it into drive during high revs....he WILL majorly F up the transmission that way.
04ShakinSteed is offline
Old 07-31-2004, 11:42 PM
vfast
I ♥ Acer
vfast's Avatar
yep if the driveshaft doesn't come out and put some holes in the trunk or worse catapoult the car over
vfast is offline
Old 08-01-2004, 11:39 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
I didn't see that part.
Also, valve float, if you happen to over rev the engine while in neutral, then it will become a problem.
Dan04COBRA is offline
Old 08-07-2004, 12:36 AM
timtimmehh
timtimmehh's Avatar
if 2000si ever reads this i was just wonderin how old that guy in the rsx was? i would've never in a million years thought it would be possible to mistake 5th gear for 2nd was it his first time driving standard trans?
timtimmehh is offline
Old 08-07-2004, 03:27 AM
Redline03GT
Redline03GT's Avatar
"So if your in like 3rd gear or something just cruising then you hold down your clutch and revv it, it will do more damage to your car? "
You are burning your clutch by doing this: terrible for the tranny. If you rev in neutral every once in a while just to show off then its ok, but dont do it too much.
Redline03GT is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
Dragonus18
09-09-2015 01:21 AM
zachary1988
09-04-2015 03:04 PM
09-01-2015 08:16 PM
Quick Reply: Is reving your engine hard on it ?
