BBK Pulley Kits
Old 11-02-2006, 03:33 PM
TeflonDon
TeflonDon's Avatar
Default BBK Pulley Kits
are the bbk undrive pulley kits any good? does anyone know?
TeflonDon is offline
Old 11-02-2006, 03:52 PM
97Stang4.6L
97Stang4.6L's Avatar
Default RE: BBK Pulley Kits
with underdrive pulleys you will get 5 -10 more horsepower to the wheels becuase they are lighter than stock pulleys. BBK is a good choice.
3.73 gear, flowmasters, o/r h-pipe, autologic chip, bbk underdrive pulleys, MAC CAI, upgraded clutch, B&M short throw shifter, Eibach sportline Springs
97Stang4.6L is offline
Old 11-02-2006, 04:16 PM
TeflonDon
TeflonDon's Avatar
do you have the aluminum ones?
Old 11-02-2006, 05:46 PM
04BlueGT
04BlueGT's Avatar
ORIGINAL: TeflonDon
I highly recommend getting steel pulleys such as Steeda. The aluminum types are all piggyback (meaning the stock crank pulley/balancer is mated to the aluminum crank pulley and then both are mounted.) I had MAC udps, which are identical to the bbk's and I ditched them after 2 months for Steeda pulleys. Yeah, cost more, but I no longer have the issues I hade with the MACs.
04BlueGT is offline
Old 11-02-2006, 05:59 PM
klfutrelle
klfutrelle's Avatar
Go Steeda!!!!!!!!!!!!!!
klfutrelle is offline
Old 11-02-2006, 06:01 PM
2004GTRED
2004GTRED's Avatar
ORIGINAL: 04BlueGT
ORIGINAL: TeflonDon
What issue did you have with the MACs?
2004GTRED is offline
Old 11-02-2006, 06:10 PM
04BlueGT
04BlueGT's Avatar
Installed easily just like the instructions said. Everything lined up and seems just fine. For about a week.
After that, if I kept the car between 2500-2800 for more than a second, the car would misfire and throw codes for the 3rd and 5th cylinders. I took it to Ford and asked everyone I could about this problem. In the end, I figured out that the pulley was causing a vibration that the crank sensor was picking up and causing the misfires. I verified that everything was bolted correctly and to torque specs. Nothing worked. I installed Steeda pulleys and I've never had that problem return. Also, once you mate the aluminum pulley to the stock dampener, it's pretty much permanent. So, going back to stock is almost impossible without purchasing a new dampener.
04BlueGT is offline
Old 11-02-2006, 07:03 PM
djb1187
djb1187's Avatar
I have steeda and love em, no problems at all. What they do is slow down your accesorys and stuff to put more power to the wheels. Kinda like A/C on Vs A/C off. I felt a lil power gain and pleaseeee ignore all the bs you hear about your battery not charing and stuff...alll false.
djb1187 is offline
Old 11-02-2006, 07:15 PM
TeflonDon
TeflonDon's Avatar
thanks guys, i'll get the steeda one's then.
Old 11-02-2006, 08:13 PM
thornton02GT
thornton02GT's Avatar
ill still prolly get the BBK ones
thornton02GT is offline
Quick Reply: BBK Pulley Kits
