Trying to squeeze a little more HP from the Bucket
Old 11-05-2006, 11:27 PM
  #21
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: Trying to squeeze a little more HP from the Bucket
ORIGINAL: WAG03GT
Where are you going to be runnin her at ?
Temple.
code3GT is offline
Old 11-05-2006, 11:30 PM
  #22
David_K
David_K's Avatar
run it at houston raceway park and youll hit 11's temple is a ****ty track
David_K is offline
Old 11-06-2006, 12:08 AM
  #23
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: David_K
I will be hitting the bigger tracks once I get the car all sorted out.
code3GT is offline
Old 11-06-2006, 12:28 AM
  #24
ackuric
ackuric's Avatar
what gears you running now code?
ahem
ackuric is offline
Old 11-06-2006, 01:01 AM
  #25
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: ackuric
ahem
4.10's
code3GT is offline
Old 11-06-2006, 01:46 AM
  #26
01yellowgt
01yellowgt's Avatar
Move the battery back, only bad think about that you will have to wire a kill switch on the back of the car.
How hard would it be to remove the Traction control module up front, on the passengers side. Havent looked into it, but does that also run the abs also, if so forget i asked.
The electic Water pump, and a aluminum driveshaft, or even a PST carbon fiber driveshaft.
Put screws in the wheels, run a few pounds less or ~10lbs. Get a higher 2 step, and tighten the struts a setting, or 2 if the front is lifting to much.. The if it spins might try loosening the rear one setting. If it can still hook get a higher 2 step.
01yellowgt is offline
Old 11-06-2006, 01:58 AM
  #27
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: 01yellowgt
I changed my 2 step from 5500 to 6000 and it made a big difference. My ABS is disabled as well as my traction control. I know I need an aluminum driveshaft, just too cheap to spend the $$ on one, just yet. I am running 12psi in the rear tires right now. I need the front to lift and carry a little longer. I am lifting the front wheels for about 5 feet. Right now, I have my front struts set at 90/10 and the rears at 50/50.
As far as moving the battery, it's too pretty to cover up in a battery box....LOL
code3GT is offline
Old 11-06-2006, 02:00 AM
  #28
code3GT
Mustang Nazi
code3GT's Avatar
My goal for this weekend was consistent 12.4-12.5's...which I succeeded tn doing. The goal for this weekend is 12.2's. We will see what happens.
code3GT is offline
Old 11-06-2006, 02:01 AM
  #29
Colorado_Mustang
Colorado_Mustang's Avatar
I haven't played with these newer alternators, but the older ones can be disabled with a switch freeing up a couple ponies. You'd better have a good battery to deal with the power the electronics needed to run the engine.
Colorado_Mustang is offline
Old 11-08-2006, 10:14 AM
  #30
idcoocheimonster
idcoocheimonster's Avatar
Ok if im not mistaken, I think its still the stock displacement is it not? How bout stroking it out to a 5.0, or even a 5.4? that should make more torque, and power should it not?
idcoocheimonster is offline
Quick Reply: Trying to squeeze a little more HP from the Bucket
