My car died on the freeway
RE: My car died on the freeway
here's a hint to the more clueless users...when it dies keep it in gear and just press and release the clutch (you may have to floor the gas also). if you're rolling, the spinning driveline will cause the engine to turn over and start to run. i do that a lot more often than i should have to thanks to a ****ty IAC valve.
oh ps, make sure you're in a gear that will put you at least above idle rpm or else it will just struggle and die again.
3.7L V6 S550 Tech 2015 - 2017
92
08-24-2018 01:44 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
