Ok, I am about to order a set of motive 3.90 gears, mgw shifter, and either a sct xcal tuner or 2 dd bullits for the rear. I need tires in the rear so I decided it was time to step up to a wider rim. Here is my dilemma. Should I get the dd bulltis for the rear or the sct xcal tuner. The reason I ask this is because I dont have money to waste (poor college student) I know the tuner will calibrate the car for the gears, but will I see any power gain on a stock car?
I would go with the tuner. You'll be able to recalibrate for your gears and mess with your tune. Thats exactly what I plan on doing soon...3.90's and XCal
your not going to see that much power from a tuner , maybe 10hp/15tq(advanced timing) . I would get thr tuner though . you can change other stuff w/ the tuner , like raise speed & rev limiter , 2-step , turn off trac control , turn off "check engine light " for mid pipe , read DTC's , datalog . first mod I got was SCT XC2 & PRP . JMO .
