caster/camber plates
Can someone enlighten me on what these do? I've been researching where some goes go with some lowering springs and then they'll do caster/cambers. I'm thinkin that since the springs offset the balance on the lower than stock, which in turn causes the camber to react differently with the tires. Meaning that it will cause more wear on either the inside or outside of the tire. Do the caster/camber mods balance this out so to say?
RE: caster/camber plates
yes, basically, when you lwoer the car a certain amount, the wheels will bend inward at the top, so you ahve to get teh caster camber plates, inorder to bend em back out and make them level.
1.5+inch drop, you will 99% chance need the plates, only person i know that didnt, and this amazes me, is kadence. either A. his **** is magic, or B. he's got a custom plate that isnt adjustable. we cant figer it out
maestro1024
09-21-2015 02:40 PM
