First day at the track
RE: First day at the track
your trap was better then mine and stock i only trapped 89 so if you get your 60' down like eveyone else said to like a 2.1 or 2.0 you should be able to hit a 14.7 which is really good for a stock npi.
Your street tires aren't the right compound. The hotter they get, the greasier they get. A quick spin (barely any smoke) just to CLEAN them off is good. Don't bother dropping any air pressures on stock tires either.
Sounds like you have a perfect almost sea level track. Get some practice and you'll crack 14's. You're right there...
make sure that both tires are spinning i had a 95 gt and i ran good as long as both tires spun it might feel like they are but if you come out of the hole barely moving then prob one is spinning. the posi get some age and dont work as good
[IMG]local://upfiles/42590/7E18945593894F01AF51E1B9B1D099F6.jpg[/IMG]
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
