JERRY RIGGIN???
JERRY RIGGIN???
My car needs a blower. But I have a pre 99 wit tha headswap. So that makes my compersion ratio a bit high. (From wut i hear unfriendly for boost). So is it possible to use some thick a$$ gaskets to make the compersion ratios to drop??????? To make it boost friendly. (*** you can tell i dont feel like changing the bottom end).
MONTY
MONTY
RE: JERRY RIGGIN???
I don't see you being able to drop the compression by more than a couple points with thick headgaskets - and that would suck to go through all that trouble over again. You can still supercharge, but I wouldn't advise running more than 5 or 6 lbs - maybe a real good tuner could get you more, safer, if you intercool - but no way more than 8 and thats really pushing it. I wouldnt be afraid of running 6 lbs though, and thats still good for probably about 75 hp or so on your car.
RE: JERRY RIGGIN???
ORIGINAL: jdaniel
Dude... People put blowers on PI motors all the time. Ask GreyGhost... He just did it and he loves it from what I hear. No need to change the compression unless you absolutly want to.
MD, thanks for the reply. So it is possible? Also you SEEM to know alot bout blowing (lmao no pun intened). With tha atmosphic jib jab. So i have another question. With me running less lbs of boost on a engine with more compression would this give me the equivlant horse power to a engine running more boost but less compression???????
THANKS, MONTY
RE: JERRY RIGGIN???
Well it kinda does, but ultimately you won't be able to run as much timing or a better fuel curve as a lower compression motor.
There's some dude on another forum running 10# of non-intercooled vortech boost on a PI swapped stang... lol but he was called unintelligent to say the least - apparently he had the $$ to pay for a new shortblock though...
