99-04 PI swap into a 96GT
I have been discussing my oil disappearing issue in the thread "self proclaimed 4.6L experts" I was advised to do a PI swap...can someone direct me to the proper sites or links that would assist me this swap. I want to research it and look into what I am facing this winter. Thanks again....THIS SITE IS FU**ING AWESOME hahaha
RE: 99-04 PI swap into a 96GT
Well i read your oil issue thread and unless your sure its valve seals pi swap might not solve your prob. There are alot of dif things that could cause oil consumtion from leaks to burning. If you really want to resolve this first you need to find out were the oil is going.
Ok i went back and read the rest of your thread and here is my advise for what its worth.
PROMAR RACING ENGINES
10 Peach Street - Paterson, New Jersey 07503
973-684-1500 Fax: 973-684-1212
Toll-Free 1-800-422-6022
Steve Connington
4.6 P.I. engine components(specs)
Production 4.6 Romeo block, studded mains, bored and stress-plate honed .020( 3.571)
New factory Cobra steel crank
Eagle H-beam rods with ARP 2000 bolts
Probe 18cc dish forged piston (9.1:1)
Factory P.I. cylinder heads with 44cc chamber
Factory P.I. camshafts 192/184 duration @.050 .535/.505 lift
ARP head stud kit and MLS Fel-Pro head gaskets
Balanced rotating assembly +/- 1 gram
These are the additional parts and services featured on this engine.
Everything else is remanufactured to stock specs (bearing clearances etc…)
Ask for John and tell him steve sent you.
He can set you up with a reputible installer in your area also.
With the dished pistons you will be dodging the 10:1 pi swap dilema.
Guarantee you no more oil disapearing after you do this lol
Steve Connington
Do you mean that if I do a head swap I will still have the oil problem. I know that is the first issue to address but after that I need the direction on what to do? I got some great help from another member on th swap. I guess my question is do I need to do the total engine swap or would I be better off changing internals and upper/lower intake and other acc.
What he is saying is that if you do the pi swap and it turns out that your valve seals weren't the reason you were losing/burning oil then it won't fix the problem. You need to diagnose the problem before you can fix it. A PI swap is a great thing to do but if you have a bad ring on a piston or a leak somewhere you will still be here asking where is my oil going.
step 1 : find a junkyard with a 99-04 mustang GT
step 2 : ask if the motor is damaged.
step 3 : if the motor is ok, ask how much and check the miles on the car.
step 4 : if the milage is about 50k or less, then take it.
step 5 : give tehm your motor, and 1500, and your nice PI motor will now be inside your mustang.
step 6 : get an adapter for the air senser harness on the intake mani. as the 99+ only have 1, and the 96-98 have 2
ORIGINAL: trance565
Find a complete junkyard motor and have yourself a brand new engine.
Matt's 95 Stang
10-05-2015 07:16 AM
