Heads & Cams????
Old 11-27-2006, 04:33 PM
02 Ninja
02 Ninja's Avatar
Default Heads & Cams????
I have an 02' GT with 90k miles. I have bolt on mods, but would like to know if adding heads and cams at this point would be a good idea.
02 Ninja is offline
Old 11-27-2006, 06:28 PM
04BlueGT
04BlueGT's Avatar
Default RE: Heads & Cams????
If your rings are still good, there is no reason really not to. However, Stage IIIs will make daily driving a little rough. I'd also P&P the intake (gasket match) otherwise it will become something of a restriction.
You'll need a good dyno tune to make it work right. I hope the local shop uses the predator, otherwise start saving for the SCT.
04BlueGT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Heads & Cams????
