Maintenance?
Old 09-07-2004, 03:47 PM
2000SilverGT
2000SilverGT's Avatar
Default Maintenance?
Well as most of you know I just got my car last week. Its a 5 speed 2k GT with 65k miles. Is there any maintenance work you guys suggest I do? I already have a K&N filter and using Royal Purple oil.
2000SilverGT is offline
Old 09-07-2004, 04:06 PM
2001_SaleenS281_08
2001_SaleenS281_08's Avatar
Default RE: Maintenance?
drive it hard to work the kinks out, race everyone you see just to make sure you're the boss, that's always good maintenence
2001_SaleenS281_08 is offline
Old 09-07-2004, 07:05 PM
USAMuscle
USAMuscle's Avatar
At about 60k, you might want to replace the spark plugs. Also check the belts and hoses for cracks, change your transmission and rear end oil, and not sure when it's technically supposed to be done, but maybe flush the cooling system. Take a look at your brake pads also to see how much you have left. Do all that and you'll have a fresh start with your car. Oh yeah, and check the fuel filter to see if it needs to be replaced. If it wasn't done before you bought it, or you're not sure, change the oil just to be safe.
USAMuscle is offline
Old 09-08-2004, 03:10 AM
94Cbra
94Cbra's Avatar
Definatly change the oil, even if whoever had it before you said they did. Do it anways. If your not using Mobil 1 Synthetic, go ahead and put that in it (just dont ever change oil brands again unless you have to for some reason). USA hit it on the head, so do everything he was talking about. If the coolant hasnt been flushed then go ahead and do it. Its recommended at around 55K miles.
94Cbra is offline
Old 09-08-2004, 03:30 AM
Monty
Monty's Avatar
Why does he have to stay with mobil one??????
Monty is offline
Old 09-08-2004, 05:27 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
He doesn't. It's just a bullsh*t myth about synthetic oil.
All the myths and rumors about synthetic oil **** me off.
1) YOU DO NOT need the FLUSH KIT.
2) You can switch back to conventional oil anytime, but why would you ever do that?
3) I just farted.
Dan04COBRA is offline
Old 09-08-2004, 02:56 PM
2000SilverGT
Well I already changed my oil with Royal Purple 5w-30, also I used a K&N oil filter. Then I flushed radiator and put in Ford coolant with Waterwetter. Then I used Redline fuel injector cleaner. Im looking into changing spark plugs, whats a good brand to get?
Old 09-08-2004, 03:30 PM
94Cbra
94Cbra's Avatar
Why does everyone get so defensive so quick on these forums? It was just my opinion, he asked me what I would do and i told him, I didnt mean anything about the bs rumors or anything... All I was saying was that I wouldnt ever change from Mobile 1 unless for some reason I had to just because I really like that particular oil... god d*amn...
94Cbra is offline
Old 09-09-2004, 01:52 AM
04ShakinSteed
I ♥ Acer
04ShakinSteed's Avatar
ORIGINAL: 2000SilverGT
Good job! Also change the tranny fluid and replace with a good synthetic.
For the plugs, get the Iridium plugs.
04ShakinSteed is offline
Old 09-09-2004, 02:01 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
FUEL FILTER!!!!!!!!!!!!!!!!!!!!!
Mine was so clogged after 45k miles I couldnt blow through it! I didn't notice any symptoms at the time from it being clogged but when it got bad enough to lower my fuel pressure substantially I woulda found out! (can you say lean = boom?)
CHANGE THE FUEL FILTER!
mdvaldosta is offline
Quick Reply: Maintenance?
