Where is the Sound????
Old 07-22-2003, 01:02 AM
mustangfreak281
mustangfreak281's Avatar
Default Where is the Sound????
I have a 98 gt and i removed the air silencer and everyone says that it makes a cool noise...i did the removal but there seems to be no difference. i have a k&n air filter. is my problem a dirty filter, and if so, what can i expect performance and noise wise if i clean it?
mustangfreak281 is offline
Old 07-22-2003, 01:24 AM
Jugador
Jugador's Avatar
that's not the problem i don't think...turn the radio off, make sure everything's quiet and listen at about 4000 rpm's and it's really not that cool, just a sucking noise. but it's always good to clean the filter to get more air in i would think...but i'm saying everything i "know" in theory, not practice. but i do know about the silencer cause my brother did it.
Jugador is offline
Old 07-22-2003, 02:15 AM
99dropTop
99dropTop's Avatar
you wont hear anything... alrite u might hear something above 4000 rpm, i can hear mine beacuse its a vert... its just a dumb mod.
99dropTop is offline
Old 07-22-2003, 02:29 AM
Zcpeanut
Zcpeanut's Avatar
people say its the first mod they do b/c it basically does nothing, but it does help the air intake a little, i didnt hear anything when the guy at my school did it
Zcpeanut is offline
Old 07-22-2003, 11:07 AM
Alex52
Alex52's Avatar
i'm sure it doesn't do much at all - but it's one of those things you can do when you've got a little time on your hands and 3 cents in your bank account (which happens to be exactly what the bank statement i just got says i havelol)
Alex52 is offline
Old 07-24-2003, 01:32 AM
yellowstang
yellowstang's Avatar
I did it , and got the k&n air filter , just before i added the complete intake , andI could hear it sucking just by letting the car idle then "gunning" the throttle real quick.
yellowstang is offline
Old 09-14-2003, 04:48 PM
yellow02
yellow02's Avatar
yeah it helps not much but it helps and u hear a sucking noise that means u r gettin more air to your throttle body keep the filter clean u can also make a homemade cold air intake system for about 30bucks that works just like a cia from a performance store
yellow02 is offline
Old 09-14-2003, 08:01 PM
gdear66
gdear66's Avatar
It does nothing. A K&amp;N filter alone may give another 1-2 hp high in the rpm curve.</P>
Don't overclean the filter either. If you read the package it says to clean and recharge the filter every 80-100K miles. Overcleaning it will actually wear it out and you'll end up allowing more dirt into the engine, increase wear, and wear your engine out faster.</P>
gdear66 is offline
Old 09-26-2003, 09:05 PM
krsllac
krsllac's Avatar
I notice that in about 6,000 miles if i clean my k&amp;n filter my car runs much better.So i clean mine any time that my 99 GT needs it<IMG src=smileys/smiley1.gif border="0">
krsllac is offline
Old 10-10-2003, 06:19 PM
drichard
drichard's Avatar
krsllac,</P>
if you wash it often, you're might run better because your damaging the filter, allowing more air but also dust particles to enter... That might not be wise in th elong term. Some Racers completely remove the air filter, but they don't mean to keep the car for thousands of miles...</P>
drichard is offline
Quick Reply: Where is the Sound????
