How Can You Tell if a COP is BAD?
Old 12-28-2006, 02:40 PM
4.6LPoppy
4.6LPoppy's Avatar
Default How Can You Tell if a COP is BAD?
[sm=helpout.gif] How can you tell if you have a bad coil on plug? In the past I have stuck a new one in the holes until I found where it smoothed things out. What happens if you have 2 bad? This method won't cut it. Is there a tester?
4.6LPoppy is offline
Old 12-28-2006, 03:03 PM
GT 281
GT 281's Avatar
Default RE: How Can You Tell if a COP is BAD?
Feed him a donut.
GT 281 is offline
Old 12-28-2006, 03:21 PM
4.6LPoppy
4.6LPoppy's Avatar
ORIGINAL: GT 281
Feed him a donut.
Somehow, I knew this would happen. Good answer though. (Still need to know)
Old 12-28-2006, 04:03 PM
mikev08826
I ♥ Acer
mikev08826's Avatar
Kind of a bogging feeling...it will feel like your only running on 7 cylinders...tough to explain...
mikev08826 is offline
Old 12-28-2006, 04:16 PM
4.6LPoppy
4.6LPoppy's Avatar
ORIGINAL: mikev08826
I know that feeling from previous 4.6's, but they were all essentially stock, either SOHC or DOHC. This one has Procharger, MSD ignition, 42lb injectors, etc, etc. and I can't tell if it is from some of that or if I have a bad COP or COPs. It runs GREAT when I step on it but is real rough around 1300 rpm.
Old 12-28-2006, 04:19 PM
Sap
Sap's Avatar
You will get a Check engine light if one goes bad. I also imagine it would be pretty obvious as one cylinder would just stop working.
E.
Sap is offline
Old 12-28-2006, 04:33 PM
Fallstar01
Fallstar01's Avatar
It should throw a code telling you which cylinder isn't fireing correctly.
Fallstar01 is offline
Old 12-28-2006, 05:20 PM
4.6LPoppy
4.6LPoppy's Avatar
ORIGINAL: Sap
E.
The minority of my engine is not stock so the eng light is always on. A COP can go 10% bad/weak. When one is going bad it starts with just a slight hiccup now and then.
Old 12-28-2006, 05:24 PM
aode08
aode08's Avatar
NO YOU WILL NOT GET A CODE 70% of the time till the car does not want to run
Have it put on Oasis at Ford, you may have several issues, . Had a 4.6 with 4 bad Cops and it idled wierd and miss every now and then.
No codes, Oasis will test each one and monitor the system, way better than the ECM can do its own self[:-]
if you have a bad cop, I have 8 Excellent ones from Ford. What we do is repalce all eight under warranty and keep the good ones to ourselves, in this guy case, his misfire were the garbage platinums in the motor and not the COP'S, so I have 8 of em with 10k on them, still smells brand new from an 2002 4.6
aode08 is offline
Old 12-28-2006, 05:26 PM
sk8erdudex
sk8erdudex's Avatar
pull the engine codes if the light is on. It will tell you all the codes. Including which cylinders suck
sk8erdudex is offline
Quick Reply: How Can You Tell if a COP is BAD?
