My Custom Cobra-r front bumper
RE: My Custom Cobra-r front bumper
ORIGINAL: JonBeast
Sweet man, gotta love it when someone does something different!
should look good
Damn dident see the old posts. I got my third brake light from www.stangmods.com. I used the bezels front the projector fog light kit off of ebay and cut them to fit. Then basically molded them in with fiberglass. Then I bondo'd them smooth and primed.
Thank you
Im from North Las Vegas around craig and simmons.
The kit is just a cheap one off of ebay. I only used a little bit of the chrome bezel and the Projector light.
http://cgi.ebay.com/ebaymotors/7-COL...spagenameZWDVW
50 bucks aint bad.
Thanks
50 bucks aint bad.
Thanks
ORIGINAL: /\CHRIS/\
Thank you
50 bucks aint bad.
Thanks
Thank you
50 bucks aint bad.
Thanks
I got them from ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...;rd=1&rd=1
If you get a set make sure you seal them all the way around with bedliner or silicone or something cause these things will get condensation like crazy.
They look great with HID's
Thanks
Basically I have 2 HID kits 1 set for the headlights and 1 set for the fog lights. These kits are really easy to install. You just hook up both + to the battery or constant 12v, then the 2 blacks to ground. You will have 2 white wires one on each kit that will be the the triggers that are used to turn the lights on. I just used my drives side fog light + wire which should be a brown wire with a red stripe. I used that to trigger my fog lights so I can use the factory fog light switch. Then I tapped into my low beam wire. (There will be a low beam/ground/high beam) Just use a volt meter and find out which wire has 12vwhen the low beams are on and use that wire as the other HID kit trigger for the headlights.
Then just put the lights in the housing and have fun.
This way you use your factory switches in the car to power the HID's. I don't have hi beam HID's,, but with the fog lights I have more than enough lighting. If you buy your kit from stangmods and are going to install HID's in projector headlights like mine ask them to send you instruction on how to. They have really good instructions on how to do it properly. Basically you have to do a little but of cutting to get the bulbs to fit in the housings.
The picture below is what it looks like.
