When i did this mod, I purchased the IAC restrictor off ebay and it would make my car turn off. Any suggestions on how i can fix this?
That probably means the hole is too small. Not sure what kind of piece it is but if you can try making the hole a bit bigger until the engine doesn't just stall.
The material is kind of cardboardish, the ebay add had it in a aluminum looking material but i guess this is what it really is. The wholes are about the size of a hole punch, im going to make them a little bigger in the morning. Thank you
I was gonna do this mod but I've decided not to. Didn't want to risk having my engine stall if I am going like 40mph and then putting it into neutral causing my steering wheel to lock
Strider, your steering wheel wont lock if the car stalls, it will only lock if you turn the key to the off position
Nope. I was going 30mph, my car turned off, my steering wheel locked, i luckly braked right before i went onto the sidewalk, ****KK it was embarrassing.
