Video of my engine problem- What's wrong?
Old 02-11-2007, 11:49 PM
2000GTFOOL
2000GTFOOL's Avatar
Default Video of my engine problem- What's wrong?
Ok watch this and listen to the sound.. Noise started after an oil change, went to a thicker oil this last oil change and it didn't make a difference. Only does it when I start it up when it's cold after it warms up it doesn't make a noise. Any ideas? I took it to the dealer and they were clueless. The exhaust bolts are tight.. Make sure to watch what happens as I remove the oil cap....
http://www.youtube.com/watch?v=R0tBoYw_Pow
2000GTFOOL is offline
Old 02-11-2007, 11:54 PM
99gtstang
99gtstang's Avatar
Default RE: Video of my engine problem- What's wrong?
ORIGINAL: 2000GTFOOL
how many miles are on it? have you tried lucas?
I've had 3 fords all have some sort of morning rattle especially my mustang i have to stay below 1500 rpms for about 3 miles untill the knock goes away..... but i know there are nylon gears around the timing chain they could be worn and untill lubed up can cause a rattle but i've never heard anything like that though
cam caps? maybe i really don' know
99gtstang is offline
Old 02-11-2007, 11:55 PM
St4ng07
St4ng07's Avatar
Sounds like bad valve to me....
St4ng07 is offline
Old 02-11-2007, 11:59 PM
xander0561
xander0561's Avatar
I have a 96 GT , and I had a tick like that , turns out it was a spark plug arcing. Check things like that, sometimes its hard to distinguish where its really comming from, over all the other noice. Also if you think you know where the problem is. Take a "long" strew driver and put it on the problem area, and place your ear to the handle, you can hear whats goin on inside. I would place it on the injectors and your alternator. Anything that could tick. Hope any of that helps.
xander0561 is offline
Old 02-12-2007, 12:00 AM
Fuel
Fuel's Avatar
my car has a sound alot like that but not quite as severe when i start it up too
Fuel is offline
Old 02-12-2007, 12:03 AM
bransdaman78
I ♥ Acer
bransdaman78's Avatar
sounds like a valve... try some belt quiet and see if that makes a diference... check all your lines, in the vid sounds like it gets louder with the oil cap off... like a valve
bransdaman78 is offline
Old 02-12-2007, 12:14 AM
2000GTFOOL
2000GTFOOL's Avatar
Car has 78k on it.. Started 5k miles ago. Anything I can check myself?
Old 02-12-2007, 12:19 AM
mylongvictor
mylongvictor's Avatar
You can try going synthetic oil if you hadn't already done so with your next oil change.
mylongvictor is offline
Old 02-12-2007, 12:26 AM
2000GTFOOL
2000GTFOOL's Avatar
I really would like to fix it rather then just make it go away.. I plan on keeping the car for a while...
Old 02-12-2007, 01:48 AM
Steve04GT
Steve04GT's Avatar
I would Try mobil 1 5w-30 full synthetic and use the lucas oil additive andsee if that helps.... if its still the same thing I would get it checked out.
Steve04GT is offline
Quick Reply: Video of my engine problem- What's wrong?
