C&L intake Plenum
C&L intake Plenum
Im thinking about buying a new intake plenum from C&L from a friend for $140. I have a few questions.
1. Is this a good cost?
2. Will it work with my stock TB?
3. What gains could I expect with just a plenum upgrade without the TB?
RE: C&L intake Plenum
can someone please answer his post... im wondering the same thing, would it be too much of a jump to gain? would you lose HP if adding the plenum too soon on a stock motor? do you need to get the massair and TB also to get any gain?
yes it will work i have the same setup don't get the 75mm tb they normaly sell with it it is too much if u do get a tb get a 70mm i don't know the exact gain alone but i have the stuff u see below and i made 256rwhp not a rocket but quite a bit better than stock. but when i got the plenum i noticed an immiedate diffrence better throttle response also
ORIGINAL: Master
I have seen the plenum swaps for 7-10 hp, and then a 75mm T/B only gaining 2-3 more rwhp. The throttle body does not appear to be a large restriction on a bolt ons only motor.
