P1451 Lack of Response From Passive Anti-Theft System Module - Engine Disabled. fix?
Old 02-16-2007, 05:29 PM
mariotraci
mariotraci's Avatar
Default P1451 Lack of Response From Passive Anti-Theft System Module - Engine Disabled. fix?
autozone says its dealer code?
mariotraci is offline
Old 02-16-2007, 08:55 PM
8banger
8banger's Avatar
Default RE: dealer code 1451????????
I checked and if its a p1451.....its prob the canister (CV solenoid)ventsolenoid..I don't know why this would be a dealer code though.....
8banger is offline
Old 02-16-2007, 08:56 PM
8banger
8banger's Avatar
Are you sure when you dropped the tank(to change the pump),,you plugged everything back in?
8banger is offline
Old 02-16-2007, 08:59 PM
mariotraci
mariotraci's Avatar
what is that?how do it fix it? all for o2s are bad. i need to deletethe back two and buy new ones for the front. they just said there book did have that code it was a dealer code????
Old 02-16-2007, 09:05 PM
mariotraci
mariotraci's Avatar
ORIGINAL: 8banger
didnt unplug anything besides whats in the tank. could have pinch something putting the tank back up. Its a pain to put gas in it. (nice and slow)
Old 02-16-2007, 09:07 PM
8banger
8banger's Avatar
I believe....if you look above the drivers side tail pipe(the end of the pipe),,,you'll findthe solenoid and the evap canister....little round solenoid ,,,looks kinda like a little fuel pump with a plug in the end of it....make sure its plugged in,,,and all the evap lines are on .....also need to check all fuses....I'm at home and dont have a wiring diagram to look at ,,but can tomorrow...
8banger is offline
Old 02-16-2007, 09:15 PM
mariotraci
mariotraci's Avatar
not something to worry about but get fixed soon?
Old 02-16-2007, 09:17 PM
8banger
8banger's Avatar
Nahhh,,Evap codes are just a pain the azz......
8banger is offline
Old 02-16-2007, 09:20 PM
mariotraci
mariotraci's Avatar
thanks alot i appreciate your help
Old 02-16-2007, 10:52 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
It is a dealer code. Anything that starts with a "1" is a manufactor specific code. Here's a breakdown...
- First Letter:
B - Body
C - Chassis
P - Powertrain
U - Network
- Second Number:
0 - Universal SAE
1 - OEM Specific
- Third Number
1 - Air/Fuel Metering
2 - Air/Fuel Metering (Injector Ckt.)
3 - Ignition/Misfire
4 - Auxiliary Emission Controls
5 - Vehicle Speed Control/Idle Control
6 - Computer Output Ckt.
7 - Transmission
8 - Transmission
- Fourth and Fifth Number
00-99 - Fault Number
96GT226410 is offline
Quick Reply: P1451 Lack of Response From Passive Anti-Theft System Module - Engine Disabled. fix?
