speedo gear or speedcal???
I got the white speedo gear for my 3:73's up from factory 3:27's. I have heard that these get chewed up, how long do they last? If I can get 10kmi outta it then that's fine with me that's ofcourse if it's even close to accurate (within 5 miles an hour) I really don't wanna spend $90 on a speedcal by Brothers because then I should just get a tuner in a box if that's the case? Any one know of the chewed up gears???
RE: speedo gear or speedcal???
They shouldn`t get chewed up at all. I know that when you change them they aren`t 100% accurate though. A speedcal will be dead on. I`m sure you can get a used one off ebay or check the classifieds here.
ORIGINAL: sprostang
ORIGINAL: 97targa
ORIGINAL: BuzzCut
If you like changing that gear on a regular basis then use it. It doesn't correct the speedo 100% anyway. Speedcal is 100% adjustable to any combination you have. It is your choice but I wouldn't want to keep doing things over. Pay now or pay later, your choice.
ORIGINAL: 97targa
I put the white gear in my 98 last summer. No problem in the 1000 or so miles since then.
It was about as accurate as the original speedometer before the gear swap. I'm satisified with the 15 buck plastic gear.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
