Autometer shift light wires?????
Im about to install my autometer digital shift light andI need to know were to run the wires. There isa green wire that should go to the negitive side of the coil but I'm not sure where that is. Also the red wire needs to run to a postive line that is hot when the key is on. What wire is that or could I just connect it up to the battery. The black is ground that is easy. And finally the blue is listed as "optional". Do I really need to run that if so where? Thanks a lot for your help.
RE: Autometer shift light wires?????
you will need an adapter. I dont know if you have a 99-04 but they dont have coils which means we need that queer adapter. call autometer and ask them for specific details. tell them your situation and they will help.
ORIGINAL: hitsman10
thanks you guys ill look around for one in the morning
were do i run the positive wire so that the gauge only turns on when the key is in the ignition???????
