Boost wrong?
Old 03-19-2007, 12:12 AM
TrucidoDeus
TrucidoDeus's Avatar
Default Boost wrong?
hey guys. just bought this stang, its runnin a vortech v2 s trim with a 7-9 psi pulley. when im cruisin the boost reads at -2, but the boost never goes above 4 psi accordin to the gauge? i live in montana too, could it possibly be because i live in high altitude area? any ideas guys? plz...lol
TrucidoDeus is offline
Old 03-19-2007, 12:58 AM
HaV
HaV's Avatar
Default RE: Boost wrong?
Altitude would not matter for the boost your making.
I would definatly check for boost leaks. Also check and make sure your belt is tight. Also you might have a shop test your boost gauge.. not exactly sure how to go about doing that, but it could be off.... but most likely you have a leak somewhere between your outlet piping and your throttle body...
HaV is offline
Old 03-19-2007, 12:59 AM
2000GT4.6
2000GT4.6's Avatar
+1
Check for a boost leak, and if you don't find one get the boost gauge checked. What pulley is on the supercharger?
2000GT4.6 is offline
Old 03-19-2007, 12:51 PM
TrucidoDeus
the stock pulley is on it right now
Old 03-19-2007, 01:09 PM
nanaki
Retired MF Moderator
nanaki's Avatar
are you looking at your gauge while just cruising as you stated? if so, you're not going to be in boost. and are you getting that max of 4psi when you get damn near redline? if you're only reading your gauge at cruising speeds and only taking it up to like 4500rpm, then you're fine. centris don't make max boost til about redline.
nanaki is offline
Old 03-19-2007, 01:13 PM
TrucidoDeus
no, i'm watchin it when i get on it too. i watch it all the way up till red line too.
Old 03-19-2007, 01:33 PM
CobraSnake
CobraSnake's Avatar
it sounds to me like you gotta get something checked out. Sounds like your getting 6psi right now and you probably should be closer to 8.
CobraSnake is offline
Old 03-19-2007, 01:41 PM
nanaki
nanaki's Avatar
you runnin an intercooler too?
nanaki is offline
Old 03-19-2007, 01:54 PM
TrucidoDeus
no, no intercooler. im gonna be spendin some time diggin around in it today after work, ill let you guys know if i find anythin else odd about it
Old 03-19-2007, 06:13 PM
04mineralgreyGT
04mineralgreyGT's Avatar
I don't make my max boost of 9psi (somtimes gauge says 10) until 6100rpm according to my dyno chart. You're just not going high enough in rpm to get max boost. When cruising you are running 2 inches of mercury in vaccuum. Which I am normally between 10-15 in hg when cruising depending if I keep a steady throttle.
04mineralgreyGT is offline
Quick Reply: Boost wrong?
