Axles
RE: Axles
ORIGINAL: SVTBill
i wouldnt do that cuz if you're lucky enough to get 2 launches in w/o breaking something the 3rd launch def. will...imagine if you snapped your axle or broke a spider gear...locked it up..and broke your drive shaft or even transmission...not worth it to even try untill you get a built rear and drive line...IMO....the track is much stickier than the street anyhow
I broke my spider gears powershifting from 2nd to 3rd on a freeway onramp....im bsaically stock too
moral of the story...you can break anything even if your not pushing 400rwhp
RE: Axles
Look into some MT ET streets (drag radials). They are more than sticky enough for a stock rearend car.
I am gonna get a set and keep the launches under about 3000 RPM and see if I can make some 1.8 or so 60's.
RE: Axles
ORIGINAL: 1BadSonicBlue02GT
code has 28's i believe and he's pullin hard launches.
have you seen his rear end? its BUILT
31 spline axles, 31 eaton posi, 4.10 gears, t/a girdle
or something crazy like that [8D]
RE: Axles
ORIGINAL: rbstang
LOL !!!
