Axles
Old 03-19-2007, 03:03 PM
GT 281
GT 281's Avatar
Default Axles
How much can the stock 28 spline axles handle in our cars? Im pushing 400rwhp and wandering if i should even attempt to put slicks on it at the track.
GT 281 is offline
Old 03-19-2007, 03:08 PM
nanaki
Retired MF Moderator
nanaki's Avatar
Default RE: Axles
you can, but i wouldn't do hard 5k launches or something like that. which would kind of defeat the purpose of getting slicks in the first place.
nanaki is offline
Old 03-19-2007, 03:13 PM
04MustangGT
04MustangGT's Avatar
Default RE: Axles
ORIGINAL: nanaki
Does that mean...Taching it to 5000rpm's and then letting go of the break/clutch?
04MustangGT is offline
Old 03-19-2007, 03:28 PM
jman511115
jman511115's Avatar
Default RE: Axles
ORIGINAL: ponyrideGT2004
ORIGINAL: nanaki
Yeah, don't do that.
jman511115 is offline
Old 03-19-2007, 03:29 PM
GT 281
GT 281's Avatar
Default RE: Axles
So would i be ok with say a 3000 launch with 8" slicks?
GT 281 is offline
Old 03-19-2007, 03:33 PM
ASUSMC
ASUSMC's Avatar
Default RE: Axles
It MIGHT handle it once or twice depending on several other things like what kind of gears you have, how have you beat on it, so forth. Just be sure to bring a tow vehicle to the track when you do these 5k launches and don't worry about it.
ASUSMC is offline
Old 03-19-2007, 04:16 PM
jman511115
jman511115's Avatar
Default RE: Axles
ORIGINAL: ASUSMC
Hahahahahaha. Or alternately try not to beat it up too much, just go with a new rear end. Pricey... but worth it in the long run. You'll probably want to push even more power in the future anyways. With your stock setup, it's only a matter of time before you blow somthing up.
Old 03-19-2007, 04:27 PM
jpmustanggt
jpmustanggt's Avatar
Default RE: Axles
I'd just get a new rear if you're gonna do slicks.
jpmustanggt is offline
Old 03-19-2007, 06:20 PM
SVTBill
SVTBill's Avatar
Default RE: Axles
i wouldnt do that cuz if you're lucky enough to get 2 launches in w/o breaking something the 3rd launch def. will...imagine if you snapped your axle or broke a spider gear...locked it up..and broke your drive shaft or even transmission...not worth it to even try untill you get a built rear and drive line...IMO....the track is much stickier than the street anyhow
SVTBill is offline
Old 03-19-2007, 06:26 PM
04MustangGT
Default RE: Axles
Why do you even have to tach it out? Why not stomping on it when the flag goes down?
Quick Reply: Axles
