changing spark plugs
Old 03-19-2007, 05:55 PM
techsent
techsent's Avatar
Default changing spark plugs
Hi All,
Im prepping to change my spark plugs. Am I suppose to disconnect the negative battery cable before I start?
Also, to make it easier to loosen up the existing plugs, is it ok to spray a little wd-40 onto them before removing them?
Thanks,
Techsent
techsent is offline
Old 03-19-2007, 06:00 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
Default RE: changing spark plugs
i disconnect the battery just to be safe. DONT spray wd40 on the plugs, you dont want that getting in the grooves on the threading for the spark plug, and you want your tools to be able to grip the spark plug to remove them. if you want to loosen them, get a torque wrench, tighten them a little then try to remove them, this usually loosens them. and of course let the engine cool BEFORE attempting to remove any of the plugs. What kind of plugs are you going to install?
2002GTAUTOVERT is offline
Old 03-19-2007, 06:05 PM
techsent
techsent's Avatar
Thanks 2002GTAUTOVERT, I appreciate this!
Yes, I went to the ford service center and bought the motorcraft oem (which, I found out are platinum).
techsent is offline
Old 03-19-2007, 06:13 PM
2002GTAUTOVERT
Hmm, i would have upgraded, but the platinums work fine. Im running +4's right now, easier to start. Good Luck!!
Old 03-19-2007, 06:21 PM
04mineralgreyGT
04mineralgreyGT's Avatar
Your plugs should be easy to take out. They shouldn't be torqued down that hard. Mine were cake to take out when I did my s/c install.
04mineralgreyGT is offline
Old 03-19-2007, 06:29 PM
sstang
sstang's Avatar
I got some TR55's that I'm going to put in. Do I need to gap them any differently or leave them?
sstang is offline
Granatelli Sales
03-25-2016 08:01 PM
2007StangV6
01-28-2016 06:09 PM
Granatelli Sales
12-27-2015 06:28 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: changing spark plugs
