Dumb question....
Old 03-19-2007, 09:12 PM
the_most_wanted
I ♥ Acer
the_most_wanted's Avatar
Default Dumb question....
How do you nice BURNOUT? Do you just start going into first then pull the e-brake and floor it?
Just havent had a chance to try anything and dont wanna mess up my car..
thanks
the_most_wanted is offline
Old 03-19-2007, 09:16 PM
Adam03GT
Adam03GT's Avatar
Default RE: Dumb question....
[sm=roll.gif]Have you tried stomping on it? Im assuming you have a gt....but even my old V6 you just stomp the gas and you peel out....
Adam03GT is offline
ZW99GT
ZW99GT's Avatar
ORIGINAL: the_most_wanted
How do you peel out? Do you just start going into first then pull the e-brake and floor it?
thanks
The Ebrake locks the rear wheels. So that wouldnt be too great of an idea. Just floor it
ZW99GT is offline
Old 03-19-2007, 09:21 PM
Quick Shot xMLx
Quick Shot xMLx's Avatar
You would use the e-brake on a FWD car.
Is it a manual? If so just dump the clutch at like 3000+ with the T/C off.
If an auto hold the brake and hit the gas and when it revs to like 2000+ let go of the brake.
Quick Shot xMLx is offline
Old 03-19-2007, 09:24 PM
arcstng
arcstng's Avatar
i thought guys were born knowing?
-just giving you a hard time
arcstng is offline
Old 03-19-2007, 09:25 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
Listen, if you WANT to peel out, chances are its to impress a friend or a girl. I suggest pissing your money away on a gym membership to get cut as opposed to 800 dollars for new tires every 6 months. The fact that you dont know how to peel out, means chances are you might lose control, so how about you play it safe and keep it under 2rpms at all times. ha
2002GTAUTOVERT is offline
Old 03-19-2007, 09:28 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
find a wall. park a foot away from it, facing the car towards the wall. now, inch your front bumper up to the wall, so that it juuuuust barely starts to touch the wall. now, start it up, put it in gear, and just floor it. viola! the car won't go anywhere, and your tires will be spinning!
redass02gt is offline
Old 03-19-2007, 09:30 PM
SmallFeesh
SmallFeesh's Avatar
thanks
What are you trying to do?? Lay some rubber? Or do a burnout?? If you have an automatic and you want to roast the tires without moving... aka, burnout, keep your foot on the brake and floor the gas... if you have a manual, rev the car, drop the clutch and immediatly hit the brake, while feathering the gas pedal, to avoid redlining for a long time.
If you want to do dougnuts, just floor the damn thing and start turning.
SmallFeesh is offline
Old 03-19-2007, 09:32 PM
SmallFeesh
SmallFeesh's Avatar
ORIGINAL: redass02gt
[sm=insomnia.gif] [sm=icon_rofl.gif] [sm=exactly.gif]
Old 03-19-2007, 09:34 PM
GreyStang
GreyStang's Avatar
Try coating the tires with ArmorAll that outta create a burnout to impress your geek friends
GreyStang is offline
Quick Reply: Dumb question....
