lincoln dohc
Yukon Cornelius
lincoln dohc
anyone know if they use a retunless fuel supply?
will regular mustang mounts bolt to it?
i know its basically a cobra motor with different cams and a crank etc and thats its 280hp
im thinking about picking up a mark 8 from the junkyard (they have about 4 of them) and using the drivetrain in a fox
RE: lincoln dohc
ORIGINAL: rmodel65
RE: lincoln dohc
http://www.tccoa.com/articles/overall/cobrav.html
they look pretty much the same motor with a few internal tweaks, I've heard of some guys swapping in a 03 cobra motor markVIII auto tranny and the markVIII's harness into a new edge, dont know how much work it'd be for the markVIII swap
RE: lincoln dohc
Honestly it all should work fine if you replace the harness with the newedge.
The block is the same cast code as the 96-98 Cobra block which can handle 1200hp when prepped correctly.
They are a good block and worth buying, you can get a complete engine for far less than a Cobra engine. The heads are B-Series heads (96-98) cobra and are good heads when the correct cams are added. These heads can see good power gains with a simple p&p and valve oversize.
The rest of the internals are cast and the crank is a 6blt design, the rotating assembly is good for about 475-550hp when propperly tuned before the rotating assembly begins to fail.
Replacing the stock manifold with a Cobra would be a good idea as the stock is ugly Mainly because of the ease of wiring harness swap and CAI possition. I have not seen any flow numbers to know which flows better.
Grabbing a set of plastic 1998 Cobra IMRC butterflies will pick up the power a little for you too.
Lots of good stuff to have with this engine, personally I just care about the bare block and bare heads
-Eric-
-Eric-
Yukon Cornelius
RE: lincoln dohc
heck no ford blue in my vein and my ponies but i figure i could get a whole mark 8 for about 500$ and a fox notch i found for 175 and a little money doing all the swap stuff and bam
08-12-2015 05:39 PM
