Throttle body?
Guest
Posts: n/a
Throttle body?
Are there any companies that do overbores on the stock 99+ 4.6 throttle body?
I know the TB is a pretty big restriction on the 03-04 Cobras because of noise pollution laws Ford had to follow, are these any bigger than the GTs or would they be roughly the same?
thanks jd for answering me. heh
Guest
Posts: n/a
RE: Throttle body?
i already have a dremmel but I'm not going to do that myself.
Should only be like 20-30 bucks to have it bored out, but i might as well get it polished while it's out.
basically what you're saying is you don't know of any company that does this for you. thanks.
RE: Throttle body?
See, I did that with the dremmel, and I've found that things just dont come out flat, you get too many waves and surface variations, so i figured in the end, I'd probably do more bad then good and jus settled for polishing.
