Anyone with 3.90's?
Old 03-21-2007, 04:07 AM
xxkazp3rxx
xxkazp3rxx's Avatar
Default RE: Anyone with 3.90's?
Don't forget a slighty modded LS1 is capable of a 12 second 1/4 mile.
ORIGINAL: 01GTCONVERTABLE
I'm going to do more mods, probably eventually just bolt ons and maybe a small shot of nitrous as money allows. I'm also not trying to have the baddest car on the street, just one that can at least take a slightly modded Camaro...
xxkazp3rxx is offline
Old 03-21-2007, 04:16 AM
97targa
97targa's Avatar
ORIGINAL: xxkazp3rxx
I know that... With his larger wheels, and his tires he was getting better traction - that was my point. That's all.
ORIGINAL: 97targa
I had 3.90's... I also have a stepbrother with 4.10's, and had a good friend with 3.73's... all with alike mods (not exactly the same but same basic bolt ons)
The 3.90vs the 3.73 in my experiance was... I had him out of the hole pretty decently... and kept accelerating on him, he had more top end in middle to high 4th gear.. I didn't race in 5th when I had my car...
the 3.90 vs the 4.10... I got taken out of the hole (barely - he also has 18" wheels vs my 275/40-17) - we basically matched gear for gear the whole way until I started pulling on him when we both hit 4th gear...
So.. in my experiance... 3.73 = more top end... 4.10 = more low end (obviously), I found 3.90 was a good low end gear, and pulled well in top end... I felt it was a good comprimise... I would also say - it depends on where you're goin with your car.. if your just going to do this, and that's it - i may even say to do 4.30's [8D]- u just need some good tires with it... but also remember you will need a speedo recal, or a tuner... because your speedo will be off - causing your milage to be off...
Just because someone has 18" wheels doesn't mean the geomtry of the gears change! My 275/35/18's are the same size as your 275/40/17's. all within 5 or 6 rotations over a 1mile period. Depends on the tire manufacturer
MY POINT WAS 275/35/18's are the exact same size in heighth and width and carry the same traction values as 275/40/17's! There aren't any differences at all!!!
97targa is offline
Old 03-21-2007, 04:18 AM
xxkazp3rxx
xxkazp3rxx's Avatar
he has 3xx size... I forget what the actual size is... it's in the 300 size though. My fault I didn't mention that. His car gets awesome traction with his tires that he had at the time....
Old 03-21-2007, 04:42 AM
01GTCONVERTABLE
01GTCONVERTABLE's Avatar
Oh, I know all bout how much the LS1 can beat me. Last weekend a stock SS KILLED me. But my buddy has an LT1 in a Sonoma, and he still has the stock gears (in the low 3.xx's) and I just want to be able to at least run with him til about 55 before he puts 3.90's in it.
01GTCONVERTABLE is offline
Old 03-21-2007, 04:43 AM
xxkazp3rxx
xxkazp3rxx's Avatar
Fyi.. LT1 is about equal with a stock new edge.
Old 03-21-2007, 04:56 AM
01GTCONVERTABLE
Right, but since the Sonoma is so light once he get's it to hook-up, he's got me.
Old 03-21-2007, 05:14 AM
NXgt
NXgt's Avatar
I like mine.
NXgt is offline
Old 03-21-2007, 05:18 AM
geetee03
geetee03's Avatar
i did not consider 3.90's because FRPP does not make them. the 3650 has a higher overdrive gear than earlier trannys so the 4.10's would be the best choice.
geetee03 is offline
Old 03-21-2007, 05:39 AM
01GTCONVERTABLE
ORIGINAL: geetee03
Right, but like I said I have the T-45!
Old 03-21-2007, 05:43 AM
geetee03
geetee03's Avatar
oh sorry didn't read the whole thread.
on afaster note...i would still go with the 4.10's!
geetee03 is offline
Quick Reply: Anyone with 3.90's?
