Opinions
Opinions
Need some opinions on my car what do u guys suggest i should put in my engine for my car to run a 12sec. right now its running a 14.6 at the tracks some advise would be helpful on some good opinions that i might consider doing also thx guys laterz
RE: Opinions
Well working from your name and the times you run I am assuming that you have a 97' GT (Probably black) with a 5spd.
Cheapest way would be nitrous, best ways would be Forced induction and GEARS GEARS GEARS!!! lol
RE: Opinions
There is a guy on here that did a Twin Turbo build up for about $2000 dollars, he is about 473bhp with stock internals and heads. You can search for that thread and get some idea's from him, he is a smart guy and easy to talk to.
If you want to make more power on that setup I would suggest a PI head swap with a Typhoon aluminum intake, 75mm or 80mm TB (Have to open up the typhoon a little) and then do the TT job that he did and you should be just over 500hp with that setup.
In all you would probably be into the project about $3500 bux if you did it right, and by right I mean cheap without buying junk
