4.6 GT or 4.6 Cobra (differenc
#31
Originally Posted by Pyrro
Originally Posted by Power99Gt
All 4.6 two and four valve heads are aluminum. The 03 cobra block is also aluminum.
Bzzzzzzzzzzz! Wrong...The 03 Cobra block is iron, NOT aluminum. And dont forget about the aluminum flywheel and driveshaft.</P>
My bad. The 2001 Cobra had the cast Aluminum block. </P>
#32
Originally Posted by BCisme
Jeep you must remember....most shops don't mind sticking it to ya with the bill if they can get away with it. but with a lil patience and shopping im sure a good deal can be found.
#33
To convert from a 2v to a 4v is a pricey piece of cake. New cams/pullies/belts, new heads, new lower intake = 4v 4.6L. If you want to make it exactly like a cobra its a bit different because of the crank, t/b and that whole S/C system including fuel systems and pissers. And the SVT Cobra has a snake with ears all over it.
#34
jeep.... that's the sad part. whatever happened to a good deal, and service with a smile? it's like no one cares about the consumer anymore. </P>
and pyyro.... don't those pro drag cars only run 1/4 mile at a time? so i would think they could get away with aluminum, seeing as they are not subjected to prolonged exposure to heat.</P>
#35
Good point but I think the guy who enlightened me was referring to a Nascar example. Either way, as long as it holds up I'm happy.</P>
11-10-2015 11:39 AM
10-09-2015 03:27 PM
Dan04COBRA
09-30-2015 11:46 AM
