Whats PI mean
Old 03-25-2007, 12:35 PM
GrnStang96
GrnStang96's Avatar
Default Whats PI mean
I wanna buy some comp cams and this keeps coming up. I know I got a non-pi motor Its a 96 gt but should I change heads to make it pi or just non pi cams
GrnStang96 is offline
Old 03-25-2007, 12:39 PM
IWinULose
IWinULose's Avatar
Default RE: Whats PI mean
PI = Perfromance Improved. It would be better to do a PI swap, but you are talking some serious cash compared to just putting a set of good non-pi cams in.
IWinULose is offline
Old 03-25-2007, 12:45 PM
GrnStang96
GrnStang96's Avatar
Hey thanks alot your right heads are expensive I wanna save up and buy an 06 gt but I need some power I'll think about the cams and maybe the intake manifold thanks again
Old 03-25-2007, 12:48 PM
GrnStang96
GrnStang96's Avatar
Hey do u have cams in your stang
Old 03-25-2007, 12:49 PM
IWinULose
IWinULose's Avatar
Yeah... VT Stage 2 Blower
Old 03-25-2007, 01:01 PM
2000GT4.6
2000GT4.6's Avatar
A set of stock PI heads should be pretty cheap, call around junkyards and try to find yourself a set.
Alot of people recommend just doing the PI intake and a set of aftermarket cams. This should be cheaper than an entire PI swap (unless you find a deal at a junkyard) and it will make as much/more power, plus make the powerband pull all the way to redline.
2000GT4.6 is offline
Old 03-25-2007, 01:09 PM
GrnStang96
GrnStang96's Avatar
Junkyard not a bad idea but I was thinking new heads with cams u know the works but i'll look into the junkyard thing I'll see how much it is so your saying just take the heads put cams and buy the intake manifold I'll check it out
Old 03-25-2007, 08:51 PM
badboystangGT
badboystangGT's Avatar
I have the whole PI swap kit with ported heads and PI cams and PI intake manifold $750
badboystangGT is offline
