spark plugs for blower
RE: spark plugs for blower
well your car isnt going to explode or anything, but with the amount of air and fuel that will be crammed inside ur engine, ur might have some misfires or detonation at the worst. the ngk's are really good plugs, and cant u install them urself?
ORIGINAL: escalade316
this weekend I had my procharger installed but the guys that did it didnt put on the ngk spark plugs that came with the kit how could this effect my car?
K&N tests their stuff before they sell it, and they claim 15horsepower, but i get what youre saying, when u have that much air and fuel in ur engine u need some good double platinum plugs. and you will need a tune to make sure ur not running lean or rich
ORIGINAL: Machwon
Yeah definetly get some NGK TR6s in there- they are 1 heat range colder than stock. If you run stock plugs you will get some detonation.
just some info:
This should help..........
5.0
Stock E7 heads:
AUTOLITE
stock--stock 25 (5) [14m, .460 Reach, 5/8" Hex]
1 step colder--24 (4) [14m, .460 Reach, 5/8" Hex]
2 step colder--23 (3) [14m, .460 Reach, 5/8" Hex]
-----AR133 (3) [*recessed tip, racing plug]
-----AR132 (2) [*recessed tip, racing plug]
-----AR131 (1) [*recessed tip, racing plug]
NGK
stock--(UR45) 6945 (Heat Range - 4) [14m, .460 Reach, 5/8" Hex]
1 step colder--(UR55) 2248 (5) [14m, .460 Reach, 5/8" Hex]
2 step colder--(UR6) 7773 (6) [14m, .460 Reach, 5/8" Hex]
-----(R5673-8) 3249 (8) [*recessed tip, racing plug]
-----(R5673-9) 3442 (9) [*recessed tip, racing plug]
-----(R5673-10) 4050 (10) [*recessed tip, racing plug]
GT40 Heads:
AUTOLITE
stock--765 (Heat Range - 5) [14mm, .708 Reach, 5/8" Hex]
1 step colder--764 (4) or 104 (4) [14mm, .708 Reach, 5/8" Hex]**
2 step colder--103 (3) [14mm, .708 Reach, 5/8" Hex]**
-----AR473 (3) [*recessed tip, racing plug]
-----AR472 (2) [*recessed tip, racing plug]
**The difference between the 764 plug and the 104/103 plug is the thread. The 764 plug is a half thread whereas the 104/103 plug is a full thread. The full thread plugs are duplicates of the half thread plugs in every other aspect, they both protrude the same amount into the combustion chamber.
NGK
stock--(TR4) 3754 (Heat Range - 4) [14mm, .708 Reach, 5/8" Hex]
1 step colder--(TR55) 3951 (5) [14mm, .708 Reach, 5/8" Hex]
2 step colder--(TR6) 4177 (6) [14mm, .708 Reach, 5/8" Hex]
-----(B8EFS) 1049 (8) [*recessed tip, racing plug]
-----(B9EFS) 1085 (9) [*recessed tip, racing plug]
TFS, Edelbrock, and AFR Heads:
[14mm, 3/4" Reach, 5/8" Hex, gasket seat]
AUTOLITE
1 step colder--3924 (4) [*recommended starting point]
2 step colder--3923 (3)
-----AR3933 (3) [*recessed tip, racing plug]
-----AR3932 (2) [*recessed tip, racing plug]
-----AR3931 (1) [*recessed tip, racing plug]
NGK
1 step colder--(FR5) 3686 (5) [*recommended starting point]
2 step colder--(BKR6EY) 3696 (6)
-----(R5671A-8) 4554 (8) [*recessed tip, racing plug]
-----(R5671A-9) 5238 (9) [*recessed tip, racing plug]
-----(R5671A-10) 5820 (10) [*recessed tip, racing plug]
MOTORCRAFT
1 step colder--AWSF22C
2 step colder--AWSF32C
4.6 2V Bitches
MOTORCRAFT
stock--AWSF-32C (copper)
1 step colder--AWSF-22C (copper)
2 step colder--AWSFA-12C (copper)
AGSF-32C--FRPP heads
NGK
stock--TR-55/ 3951
1 step colder--TR-6 4177
1 step colder--NGK TR6
1 step colder--NGK BR6EF (Non-projected, resistor, v-groove copper)
2 step colder--NGK BR7EF (Non-projected, resistor, v-groove copper)
2 step colder--BP7EFS [PN - 3526] BR7EF [PN - 3346]
2.5 step colder--R5724-8 [PN - 7317]
3 step colder--R5724-9 [PN - 7891]
4 step colder--R5724-10 [PN - 7993]
AUTOLITE
stock--764
1 step colder--103
2 step colder--AR94
3 step colder--AR93
4 step colder--AR92
CHAMPION
YS-59C
DENSO
stock--IT16
1 step colder--IT20
2 step colder--IT22
3 step colder--IT24
5.0
Stock E7 heads:
AUTOLITE
NGK
GT40 Heads:
AUTOLITE
NGK
AUTOLITE
NGK
MOTORCRAFT
4.6 2V Bitches
MOTORCRAFT
NGK
stock--TR-55/ 3951
AUTOLITE
stock--764
1 step colder--103
2 step colder--AR94
3 step colder--AR93
4 step colder--AR92
CHAMPION
YS-59C
DENSO
stock--IT16
1 step colder--IT20
2 step colder--IT22
3 step colder--IT24
