Buzzing sound every morning!
My car is having the buzzing sound when I start the car in the morning. Someone told me that is my fuel pump. I did sent the car to mechanic but they can't tell me what is the problem because the buzzing sound would gone when the engine is warm. So anyone facing the same problem as me before? Maybe can give me some help.... Thanks!!!
ok, fuel pump is probably shot, get a walbro 255 and be carefull when ordering, so you get the right one to work with the car.. i can walk you threw the install. its easy and only takes about 2 hours...bad news is the tank needs droped... a 96 you may need a new regulator and injectors... 24lbs or 30lbs will work great and will give you better throttle responce.
you dont need to get new injectors but an adjustable fuel pressure regulator is a must. if your car is stock then you really dont need to go with that big of a pump. but you will need to replace it though.
Can i replace it by mustang 96 gt stock fuel pump and above? I did ask the mechanice to replace for me. They said if I bought myself and ask them replace for me and it will cost me around $150.</P>
Is this possible to replace myself? </P><edited><editID>96MustangGT</editID><editDate>37850.5975462963</editDate></edited>
yes that will be fine but if your are goin to have it replaced and you are planning ondoing other mods later that will require a bigger fuel pump spend a little more now and you wont have to worry about it later. it is easier to let someone else do it. the price that they gave you is not bad at all. do them a favor though make sure that you dont have a lot of gas in your tank when you go to take it in. those thing are a pain when they are full and have to drop them.
alright guys.. thanks! </P>
Beside that, I had bought a set of Maxspeed lowering spring and they want to charge me for $100 for installing the springs. Is this reasonable price? Will Maxspeed lowering spring make my car feel bumpy?</P><edited><editID>96MustangGT</editID><editDate>37850.7735763889</editDate></edited>
