Old 12-23-2015, 12:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
How to adjust the clutch.
Old 04-12-2007, 08:55 PM
rbstang
rbstang's Avatar
Default How to adjust the clutch.
So... like how do you adjust the clutch my clutch went from perfect to slipping. Is there like a **** on the transmission that you like turn or something??
p.s. for those who know me sorry i have not been around much im in the middle of moving and when this is all finished ill be back.
rbstang is offline
Old 04-12-2007, 08:56 PM
Machwon
Machwon's Avatar
Default RE: How to adjust the clutch.
you need the Steeda / UPR clutch adjuster kit- then you can adjust it on the quadrant, firewall, or cable itself.
Machwon is offline
Old 04-12-2007, 08:59 PM
rbstang
rbstang's Avatar
ORIGINAL: Machwon
so if i took it to a shop they would put this clutch adjuster kit on my car then adjust the clutch then take it off? seems like a lot of work just to adjust a freaking clutch.
rbstang is offline
Old 04-12-2007, 09:48 PM
Glen
Glen's Avatar
Ford quadrants are made of nylon and are self adjusting; pull up firmly on the clutch pedal until you hear a *click.*
You may get more than one click out of it.
But eventually, you'll want to get rid of that crappy nylon quadrant and go for a clutch adjuster kit from Steeda.
Glen is offline
Old 04-13-2007, 04:14 PM
rbstang
rbstang's Avatar
ORIGINAL: Glen
ok ill try that.
rbstang is offline
Old 04-13-2007, 07:46 PM
rbstang
rbstang's Avatar
Can anyone tell me why when i press the clutch pedal down i hear a clicking noise. is something bent or something? please help
rbstang is offline
Old 04-13-2007, 07:49 PM
P Zero
P Zero's Avatar
WHere is the clicking noise coming from? the pedal? the trans?
As for replacing your factory quadrant, whats the point? They work just fine, Ive had 10 stangs and I have yet to put an aftermarket quadrant in. People that say theyre junk = noobs.
-P.
P Zero is offline
Old 04-13-2007, 08:37 PM
rbstang
rbstang's Avatar
ORIGINAL: P Zero
-P.
sounds like the clicking is coming from the pedal... any thoughts?
rbstang is offline
Old 04-13-2007, 09:36 PM
rbstang
rbstang's Avatar
bump for me
rbstang is offline
Old 04-13-2007, 10:16 PM
klfutrelle
klfutrelle's Avatar
It could be your TOB clicking.
klfutrelle is offline
Quick Reply: How to adjust the clutch.
