p0174 code and i need help
i keep gettin this check engine light and the p0174 code. i cleaned the MAFthen iput in a new o2 sensor. i replaced the front o2 because that sensorwould lean out the fuel/air ratio correct? should i have replaced the back one? also, i dont hear any vaccum leaks
RE: p0174 code and i need help
Your right about the front sensors helping calculate the A/F ratio. It also is calculated by the MAF and TPS as well. Another guess would be that maybe you have low fuel pressure, or maybe bad injectors. Just a guess.
lincolnshibuya
12-08-2015 04:37 PM
