is this smell ok?
Old 05-01-2007, 11:43 PM
ibeeskeef
ibeeskeef's Avatar
Default is this smell ok?
I have a zex wet kit and I spray a 100 wet shot every now and again. It has been tuned and I only run 93 octane so I know it is safe. I ran out second and third gear tonight in spray just because I haven't sprayed in at least a few months. While spraying and then thereafter I smelled a heavy scent of gasoline. Now I know it is a wet kit so I should smell some gas but this was a little heavy. I do have a vert and the top was down with a heat extractor hood so the smell could have been stronger because of that, but I am not sure. I did check and there were no leakes under the hood. Is it ok to smell a gasoline smell after spraying a wet kit? Does it mean I am running way to rich or am I just smelling the "wet" part of the wet kit?
ibeeskeef is offline
Old 05-02-2007, 02:05 AM
StealthGT2V
StealthGT2V's Avatar
Default RE: is this smell ok?
well be happy you are running more rich than lean....its probably just the extra fuel that wasn't burnt up when spraying with the wet kit, but I would def take it and get it dyno tuned just to be on the safe side or check your air/fuel...
StealthGT2V is offline
Old 05-02-2007, 05:20 AM
GT STANG
GT STANG's Avatar
+1
GT STANG is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
LiquidDrink
09-29-2015 10:06 AM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: is this smell ok?
