How to spend $319
Old 05-02-2007, 01:46 AM
Reed44
Reed44's Avatar
Default RE: How to spend $319
So they dont really give you the much more hp? I dont need it to rev quicker. The 4:10's do that just fine. I want to lower it but then people will charge me ou the a** to install the kit. I like the sportline alot, what do you guys think.
Reed44 is offline
Old 05-02-2007, 01:48 AM
SINISTER
SINISTER's Avatar
What kit is who going to charge out the a** to install. If you mean the springs, that is an easy job.
SINISTER is offline
Old 05-02-2007, 01:53 AM
Reed44
Reed44's Avatar
Is it easy? I know the rear will be but I looked at the front and said, yeah definitally looks labor intensive. Will I have to get those plate things?
Reed44 is offline
Old 05-02-2007, 02:20 AM
wgdt21
wgdt21's Avatar
ORIGINAL: Reed44
yes with sportlines you will probably need C/C plates. They are like 199 on american muscle. It would be worth it though, your car will look wayyy amazing dropped.
wgdt21 is offline
Old 05-02-2007, 03:04 AM
kcp1989
kcp1989's Avatar
do upper and lower control arms. I think they have a package for 150. They are the same ones that i got and they are awesome for the money
kcp1989 is offline
Old 05-02-2007, 03:11 AM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: jsmarsh25
+1 on the short throw shifter
or maybe an aluminum flywheel
FTL
2000GT4.6 is offline
Old 05-02-2007, 03:25 AM
Sap
Sap's Avatar
If you lower you car, get an alignment, if they can align it, you dont need CC plates. Simple as that.
Be aware that you will scrape your stock H Pipe over every speed bump you encounter. I have a 1.5" drop and it's damn annoying going 2mph over bumps.. just be aware before you jump into a 2" or lower drop.
E.
Sap is offline
Old 05-02-2007, 03:50 AM
white venom
baby poop
white venom's Avatar
yeah i do too have ud pulleys and my a/c works completely fine.and i live in the DFW area. too
white venom is offline
Old 05-02-2007, 05:27 AM
Lizardbreath
Lizardbreath's Avatar
ORIGINAL: wgdt21
ORIGINAL: Reed44
IF you get the SPORTLINES YOU WILL DEFINITELY NEED C/C plates.
Lizardbreath is offline
Old 05-02-2007, 05:43 AM
1BAD3V
1BAD3V's Avatar
I'd either go with the springs or the tri-as shifter from Steeda.
1BAD3V is offline
Quick Reply: How to spend $319
