short throw?
RE: short throw?
How stiff is the centering spring in neutral? My MGW has an extremely solid centering spring, sometimes TOO solid. The stock shifter will be very loose and have lots of play while in gear and in neutral.
RE: short throw?
twist off your shifter **** and just take off the plastic panel surrounding the boot. Just squeeze the two sides together, and pull out towards youand it should just pop off (I know how that sounds, be mature). Then if you see a pure black handle going into the inner shift boot, then it's stock. Anything else is aftermarket.
Better yet, take off the plastic panel, and take pics of the shifter. We can tell with pics.
^^^ Yes that too! Mine is just like that. The stock shifter can even stay put on either side of neutral. My MGW is very stiff, and it will just pop right back into place.
